1
af
4
Wahoo Nordic
Wahoo Zwift Click & Cog Upgrade Kit
Normalpris
999 SEK
Normalpris
Udsalgspris
999 SEK
Stykpris
pr.
Ikke på lager
Tilgængelighed for afhentning kunne ikke indlæses
ZWIFT COG & CLICK Experience effortless setup and seamless compatibility between your 8-12-speed bike and Zwift Ready smart trainer with Zwift Cog, which replaces your cassette. Pair it with Zwift Click controller for silent and instant, virtual gear shifting
- Zwift Cog replaces your cassette, offering seamless compatibility with almost any 8-12-speed bike.
- Ready to assemble on to the freehub that came with the trainer
- Adjustable sprocket for chain alignment
- Zwift Click controller delivers virtual shifting at the touch of button and mounts anywhere
VIRTUAL SHIFTING Revolutionize your ride with virtual gear shifting. Enjoy silent and instant shifts at the push of a button, without moving your chain. No chain movement means no noise, less drivetrain wear and perfect shifting every time. Whether you’re climbing, cruising, or racing, the super-wide range of 24 virtual gears means you’ll always be ready for any road ahead.
- Plus and minus buttons to shift the gear up or down
- Includes a replaceable CR2032 coin cell battery. Minimum lifespan before replacing is 100 hours
- Two sizes of attachment straps for differing bar diameters
Compatible Trainers:
ZWIFT COG
- 14 tooth single sprocket
- 10 sprocket positions for quick chain alignment
- Designed to fit a Shimano HG freehub body
- Weight: 140 grams
- Dimensions: 103mm diameter x 42mm height
- Product life: tested to >25,000 miles
- Material: plastic housing and lock ring with steel sprocket
ZWIFT CLICK
- Communication: Bluetooth
- Power: Battery, coin cell CR2032
- Product dimensions: 47 x 47 x 13mm
- Box dimensions: 66 x 68 x 32mm
- Product weight: 51 grams
- Battery life: > 100 hours
