Gå til produktoplysninger
1 af 5
Wahoo
Wahoo KICKR MOVE
Wahoo KICKR MOVE
Normalpris 14,990 SEK
Normalpris Udsalgspris 14,990 SEK
Udsalg Udsolgt
KICKR MOVE Specifications
  • Product Weight: 64 lb / 29 kg
  • Drivetrain: Belt Drive
  • Power Accuracy: +/-1%
  • Connectivity: Direct Connect, ANT+, ANT+ FE-C, WiFi and Bluetooth
  • Cassette: Includes 11-speed with 11-28 ratio
What's Included?
  • KICKR MOVE
  • AC Power Adapter
  • Quick Release Skewer
  • Disc Brake Caliper Spacer
  • 1.8mm Cassette Spacer
  • Reversible hub spacer for 130mm and 135mm
  • AXIS Stiff and Easy Feet
Lav lagerbeholdning
With the introduction of fore-aft motion, the KICKR MOVE bike trainer allows your bike to move naturally for a more comfortable and realistic riding experience than ever before.
  • NEW - 8" (20cm) fore-aft motion responds to changes in riding tempo
  • KICKR MOVE base allows for additional side to side movement as well as the adjustable AXIS feet
  • Virtually silent operation
Se komplette oplysninger
Wahoo KICKR MOVE Smart Trainer
Enhance your indoor training sessions with the Wahoo KICKR MOVE, featuring dynamic ride simulation for a more natural feel. The built-in motion system allows your bike to move with your body, reducing fatigue and improving comfort during long sessions. Compatible with popular training apps, the KICKR MOVE redefines smart training for cyclists of all levels.
NEXT LEVEL EXPERIENCE
From pushing out of the saddle on an explosive attack, to finding your rhythm during a tough endurance effort, when you move, KICKR MOVE moves with you. This freedom mirrors what you feel outdoors, bringing next-level realism and comfort to your indoor rides or lock in your position for focused efforts.
MAX GRADE SIMULATION
10%
12%
16%
20%
MAX POWER(WATTS)
1500W
1800W
2200W
2500W
Wahoo KICKR MOVE Product Features
KICKR MOVE FEATURES
KICKR MOVE SPECS
ULTIMATE COMFORT
KICKR MOVE provides next-level comfort to your indoor cycling rides; the movement unleashed by its fore-aft motion reduces fatigue and improves overall efficiency, allowing you to train longer and harder than ever before.
LOCK-OUT OPTION
When you want stability or a dialed-in position, KICKR MOVE features an option to prevent fore-aft movement and lock KICKR MOVE into place.
ERG EASY RAMP
Need to pause the workout for any reason? ERG Easy Ramp™ gets you back into the effort gradually instead of requiring a leg-busting effort to hit your power numbers.
PROFESSIONAL GRADE DURABILITY
SEAMLESS CONNECTIVITY
TECH SPECS
WHAT'S IN THE BOX?
  • KICKR MOVE
  • AC Power Adapter
  • QR Drive Side Adapters for 12x142 and 12x148
  • Thru Axle Reversible hub spacer for Thru Axle
SUPPORTED DEVICES
  • MacOS: Wifi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
  • Windows PC: Wifi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
KICKR HEADWIND
Control your climate, your way, with the first smart fan built for cyclists, by cyclists. KICKR HEADWIND pairs directly to your smart trainer, heart rate monitor or speed sensor to gauge workout intensity and automatically adjust.
READ MORE
KICKR MAT
The multi-functional KICKR MAT catches sweat, insulates noise and provides a soft place to step after a hard indoor ride.
READ MORE
Video: In the Know: WAHOO KICKR MOVE Product Guide
