Gå til produktoplysninger
1 af 5
Wahoo
Wahoo KICKR Bike SHIFT
Normalpris 29 990 SEK
Normalpris Udsalgspris 29 990 SEK
Udsalg Udsolgt
    • Product Weight: 79 lb / 36 kg
    • Drivetrain: Belt Drive
    • Resistance Type: Electronic Brake
    • Power Accuracy: +/-1%
    • Crank Arm Lengths (mm): 165, 167.5, 170, 172.5, and 175
    • Rider Height Range: 5 feet (152 cm) to 6 feet 4 inches (193 cm)
    What's Included?
    • KICKR BIKE SHIFT smart bike
    • AC Power Adapter
    • Handlebar Assembly
    • Does not include pedals
    Buy any KICKR Trainer or Bike to unlock one year of Zwift for only €149,99
    Read More
    Lav lagerbeholdning: 3 tilbage
    Se komplette oplysninger
    YOUR RIDE. INSIDE.
    MAX GRADE SIMULATION
    10%
    12%
    16%
    20%
    MIN GRADE SIMULATION
    10%
    12%
    15%
    20%
    MAX POWER(WATTS)
    1500W
    1800W
    2200W
    2500W
    Product Features
    KICKR BIKE SHIFT FEATURES
    KICKR BIKE SHIFT SPECS
    REAL-TIME RESPONSE
    KICKR BIKE SHIFT's innovative brake and belt drivetrain system delivers lightning fast resistance response to grade and power changes.
    FIVE POINTS OF ADJUSTABLE FIT
    Adjust the fit of your smart bike to match your outdoor bike's geometry across 5 points - stack, reach, setback, saddle height, and frame height.
    PROGRAMMABLE VIRTUAL SHIFTING
    Customize the KICKR BIKE SHIFT controls to match shifters from the leading manufacturers - SRAM, Shimano, and Campagnolo.
    PROGRAMMABLE GEARING
    TECH SPECS
    WHAT'S IN THE BOX?
    • AC Power Adapter
    SUPPORTED DEVICES
    • MacOS: Wifi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
    • Windows PC: Wifi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
    KICKR HEADWIND
    Control your climate, your way, with the first smart fan built for cyclists, by cyclists. KICKR HEADWIND pairs directly to your smart trainer, heart rate monitor or speed sensor to gauge workout intensity and automatically adjust.
    READ MORE
    KICKR MAT
    The multi-functional KICKR MAT catches sweat, insulates noise and provides a soft place to step after a hard indoor ride.
    READ MORE
