Gå til produktoplysninger
1 af 6
Wahoo
Wahoo RPM Speed Sensor
Normalpris 499 SEK
Normalpris Udsalgspris 499 SEK
Udsalg Udsolgt
The Wahoo RPM speed sensor is the sleek, magnet-less solution for capturing cycling speed data. It easily mounts to your bike's front wheel hub, and the Bluetooth Smart and ANT+ dual band technology allows you to connect to and display data on both smartphones and bike computers. Tracking speed data has never been this easy.
  • Part Number: WFRPMSPD
  • Physical Dimensions (LxWxH): 3.175cm x.1.905cm x 2.54cm
  • Weight: 7 grams (without mount)
  • Battery: CR2032
  • Water Rating: IPX7 (waterproof up to 1,5m)
  • Wireless Signal Strength Up to 3m
  • *Note: Speed Sensor is NOT compatible with spin bikes
Click here for RPM Speed instructions
What's included?
  • RPM Speed
  • CR 2032 Battery (installed)
  • Hub Mounting Option
  • Quick Start Guide
Ikke på lager
Se komplette oplysninger
Wahoo RPM Speed Product Features
RPM SPEED SENSOR
DUAL BAND TECHNOLOGY
WIRELESS CONNECTION
MAGNETLESS
The RPM speed installs easily with no magnets required
SLEEK, LIGHTWEIGHT DESIGN
It only weighs 16.5 grams with the mount included
SPEED MEASUREMENT
Provides accurate speed data during your ride
HUB MOUNT
Mounts on most front wheel hub with a secure silicon casing
VISIBLE CONNECTION
Two LED lights show the sensor's device connection (blue) and speed detection (red)
REPLACEABLE BATTERY
No charging required. Operates on a coin cell battery for up to 1 year.
UNIVERSAL FIT
RPM Speed will fit with most bikes and frame sizes
