Gå til produktoplysninger
1 af 7
Wahoo
Wahoo KICKR HEADWIND Smart ventilator
Normalpris 3,490 SEK
Normalpris Udsalgspris 3,490 SEK
Udsalg Udsolgt
FEATURES
  • Manual Mode: Select from four speed settings to set you ideal airflow
  • Speed Mode: Pair to KICKR or speed sensor to match fan speed to bike speed
  • Heart Rate Mode: Pair to ANT+ heart rate monitor to increase airflow as heart rate goes up
SPECIFICATIONS
På lager
Wahoo KICKR HEADWIND – Smart ventilator til realistisk indendørstræning
Wahoo KICKR HEADWIND er verdens første smarte ventilator designet til cyklister. Den justerer automatisk luftstrømmen baseret på din hastighed, puls eller watt – og giver en afkøling, der følger dit træningsniveau. Med kraftig luft, app-styring og cykelspecifik ergonomi gør HEADWIND din indendørstræning både mere realistisk og behagelig.
Se komplette oplysninger
Wahoo Headwind Smart Fan
Stay cool during intense workouts with the Wahoo Headwind Smart Fan. Designed to pair with your heart rate monitor or speed sensor, it delivers a tailored cooling experience based on your performance. Adjustable fan speeds and quiet operation make it the perfect companion for any indoor training setup.
Product Features
KICKR HEADWIND FEATURES
KICKR HEADWIND SPECS
POWERFUL AIRFLOW
With wind speeds topping out at 48 kph (30 mph) the KICKR HEADWIND will keep you cool during your hardest efforts.
TARGETED AIRFLOW PATTERN
The targeted airflow pattern of the KICKR HEADWIND is designed to mirror the shape and position of a cyclist's body while riding on a bicycle.
SENSOR BASED FAN SPEED CONTROL
Control the speed of your KICKR HEADWIND by pairing your ANT+ speed sensor, heart rate monitor, or smart trainer directly to the fan. As your speed or heart rate increases, so will the fan speed.
APP BASED FAN SPEED CONTROL
Pair to the Wahoo Fitness App via Bluetooth for easy fan speed control from your smartphone.
FOUR MANUAL FAN SPEEDS
Control the KICKR HEADWIND with a simple press of a button. Four (4) preprogrammed fan speeds allow you to select your ideal airflow.
KICKR DESK COMPATIBLE
The KICKR HEADWIND was specially designed to fit with the KICKR DESK. The wheels on the KICKR HEADWIND allow you to roll the fan into position when it is attached to your KICKR DESK.
TECH SPECS
  • Part Number: WFBKTR7
  • Motor Spec: 120v 60hz
  • Dimensions (leg tucked): 41cm x 31cm x 48cm
  • Dimensions (leg extended): 46cm x 31cm x 48cm
  • Weight: 12 lb / 5.5 kg
  • Max Fan Speed: 30 mph/48 kph
  • Connectivity:
  • Adjustable Leg: Yes - 2 Positions
WHAT'S IN THE BOX?
  • KICKR HEADWIND Unit
TRAINERS
Explore Wahoo Trainers
EXPLORE
