Gå til produktoplysninger
1 af 1
Wahoo
Wahoo RPM Cadence Sensor
Normalpris 499 SEK
Normalpris Udsalgspris 499 SEK
Udsalg Udsolgt
The Wahoo RPM cadence sensor is your sleek little solution for measuring cycling cadence data. It is wireless, magnet-less, lightweight, and easily mounts to your bike's crank arm or to your shoe. Bluetooth Smart and ANT+ dual band technology allows you to connect to and display data on both smartphones and GPS bike computers. Collecting cadence data has never been this easy.
  • Part Number: WFPODCAD2
  • Physical Dimensions (LxWxH): 1.25" x.75" x 1"
  • Weight: 7 grams
  • Battery: CR2032
  • Wireless Signal Strength Up to 10 feet
Click here for RPM instructions
What's included?
  • RPM Cadence sensor
  • CR 2032 Battery (installed)
  • Rubber Mounting Option
  • Zipties
  • Shoe Mount Option
  • 3M double sided tape
  • Quick Start Guide
Lav lagerbeholdning: 4 tilbage
Se komplette oplysninger
Wahoo RPM Cadence Product Features
RPM CADENCE
DUAL BAND TECHNOLOGY
WIRELESS CONNECTION
SLEEK, LIGHTWEIGHT DESIGN
It only weighs 7 grams.
CADENCE MEASUREMENT
Provides accurate cadence data during your ride.
PELOTON IOS COMPATIBILITY
RPM Cadence easily pairs with the Peloton Digital iOS App via Bluetooth to get real time cadence data during your spin workouts.
MYXFITNESS COMPATIBLITY
RPM Cadence easily pairs with the MYXFitness App via Bluetooth to get real time cadence data during your spin workouts.
TWO BIKE MOUNT OPTIONS
(1) mount with double sided 3M tape, or (2) use the silicone sleeve and mount with zip ties.
SHOE MOUNT OPTION
The RPM can be worn on your shoe for spin classes or use with multiple bikes
VISIBLE CONNECTION
Two LED lights show the sensor's device connection (blue) and cadence detection (red)
REPLACEABLE BATTERY
No charging required. Operates on a coin cell battery for up to 1 year.
UNIVERSAL FIT
RPM cadence sensor will fit with most bikes and frame sizes
