Gå til produktoplysninger
1 af 4
Wahoo Nordic
Wahoo Speedplay POWER Single Wattmålerpedal
Normalpris 6,499 SEK
Normalpris Udsalgspris 6,499 SEK
Udsalg Udsolgt
What's Included?
Tech Specs
Lav lagerbeholdning
Baseret på det banebrydende SPEEDPLAY-pedalsystem leverer SPEEDPLAY POWER med enkelt-sidet effektmåling pålidelige og præcise data for både watt og kadence i et gennemtestet pedalsystem til konkurrencebrug. Denne kraftfulde kombination skaber en uovertruffen wattpedal, der hjælper cyklister med at optimere deres præstation ved at tilbyde den indsigt, justerbarhed og effektivitet, der skal til for at tage præstationen til næste niveau. Par med Wahoos økosystem af smarte enheder for at få et komplet billede af dine data og din præstation – og for at spore, analysere, dele og forbedre.
Se komplette oplysninger
Product Features
SPEEDPLAY POWER SINGLE FEATURES
SPEEDPLAY POWER FEATURES
+/- 1% POWER ACCURACY
Lab tested accuracy that provides a precise power measurement for all training efforts.
LEFT POWER
With a single-sided power sensor, your left side power is tracked and doubled to estimate total power output no matter where you are crushing watts.
CADENCE
With its internal gyroscope, Speedplay POWER reports out cadence data to help you identify your sweet spot effort and power output.
EASY APP-SETUP
Our simple and intuitive Wahoo Fitness app offers guided instructions on how to install Speedplay POWERs on any bike, calibrate the pedals for accuracy, and perform firmware updates.
WAHOO ECOSYSTEM COMPATIBLE
Pair Speedplay POWER meter pedals with the rest of the Wahoo Ecosystem for the most connected training experience. Track your metrics outdoors on an ELEMNT GPS Deviceor control indoors on a KICKR Smart Trainer for consistent data anywhere, anytime.
DUAL-SIDED ENTRY
Speedplay POWER is built on on the dual-sided entry SPEEDPLAY Pedal System, which maximizes power transfer by putting your foot closer to the spindle. No more fumbling, fussing or kicking your pedal over; leverage a powerful take off when the light turns green and clip in with ease.
DUAL-BAND ANT+ AND BLUETOOTH TECHNOLOGY
Speedplay POWER can simultaneously connect to three Bluetooth devices while broadcasting to an unlimited number of ANT+ devices.
ENHANCED WALKABILITY
The slim profile cleat and rubber texture create enhanced stability when walking in your road shoes off the bike.
INTEGRATED PROFILE
Speedplay POWER and the SPEEDPLAY Standard Tension Cleat create a secure connection and a streamlined profile. The two form a seamless integration that aids power transfer and increases aerodynamics.
3-AXIS ADJUSTABILITY
The cleat can be positioned on the bottom of the shoe and adjusted fore-aft, left-right and rotationally, allowing between 0-15 degrees of float.
ROTATIONAL FREE FLOAT
Speedplay POWER provides up to 15 degrees of float, allowing the heel to pivot around the center of the pedal. This range of motion in the foot, lower leg and knee increases comfort and enhances pedal efficiency.
SUPERIOR CORNERING CLEARANCE
We've adapted the best-in-class corner clearance of SPEEDPLAY Advanced Pedal System into Speedplay POWER. This pedal and cleat integration allows for a large degree of lean on the bike when riding tight corners. Pedal with confidence knowing your pedal won't strike the ground and leave the competition in the dust.
EXCEPTIONAL DURABILITY
Speedplay POWER pedals offer uncompromised durability and minimal maintenance thanks to their stainless steel construction and triple-sealed bearing system.
TEMPERATURE COMPENSATION
Speedplay POWER is tested and proven to provide accurate power data across changing temperatures that you are sure to encounter while riding.
RECHARGEABLE BATTERY
Powered by a rechargeable lithium battery, Speedplay POWER pedals have a battery life with up to 75 hours.
STANDARD TENSION CLEAT
Speedplay POWER pedals include a set of Standard Tension Cleats and cleat surrounds for an aerodynamic profile and walkable system.
EASY TENSION CLEAT
Looking for even easier unclipping? Speedplay POWER is compatible with our Easy Tension Cleat, which can be purchased separately.
