Gå til produktoplysninger
1 af 9
Wahoo
Wahoo SPEEDPLAY: NANO Pedal System
Normalpris 4,799 SEK
Normalpris Udsalgspris 4,799 SEK
Udsalg Udsolgt
Hvad er inkluderet?
  • Left and Right Pedals
  • Cleat Assembly
  • Screw Packet
  • Quick Start Guide
Additional Tools Required for Assembly: #2 Philips Head Screwdriver and 6mm Allen Wrench
Tekniske specifikationer
  • Part Number: WFPRN1S53
  • Physical Dimensions: 9,9cm x 5.08cm x 5.08cm
  • Shipping Weight: 0,5kg
  • Box Dimensions: 15cm x 5,08cm x 9,9cm
  • Country of Origin: Vietnam
  • Weight: 168g per pair
  • Stack Height: 11.5mm (3 hole) 8.5 (4 hole)
  • Q Factor: 53mm
  • Spindle Material: Titanium
  • Cornering Clearance: 39°
  • Max Rider Weight: 180lb / 82kg
  • Cleat Fore - Aft Adjustability: Up to 13mm
  • Cleat Left - Right Adjustability: Up to 8mm
Lav lagerbeholdning
The SPEEDPLAY NANO racing bike pedals are a featherweight, dual-sided road bike pedals that live up to the demands of sprint finishes, categorized climbs, and tough training sessions. The mix of premium titanium and carbon fiber materials create an ultra light but strong pedal that will hold up and deliver speed on the breakaway. The integrated cleat system with 3-axis adjustability allows you to precisely dial in your fit for optimized biometrics and increased power transfer.
Se komplette oplysninger
  • Dobbelt indstigning
    SPEEDPLAY NANO-pedalers symmetriske design giver mulighed for indklipning fra begge sider. Ikke mere fumlen, besvær eller at skulle vende pedalen – kør afsted, når lyset skifter til grønt, og klik nemt i.
  • Forbedret gangkomfort
    Den slanke klampeprofil og gummistruktur giver bedre stabilitet, når du går i dine landevejscykelsko uden for cyklen.
  • Integreret profil
    SPEEDPLAY NANO-racercykelpedaler og Standard Tension Cleat skaber en sømløs integration for en strømlinet profil. Den sikre forbindelse kan bidrage til øget kraftoverførsel, hvilket gør det lettere at opnå de hårdt tilkæmpede watt.
  • 3-akse klampejustering
    Standard Tension Cleat kan placeres under skoen og justeres frem/tilbage, sideværts og roterende, hvilket giver 0-15 graders bevægelsesfrihed.
  • Roterende fri bevægelse
    SPEEDPLAY-pedaler giver op til 15 graders bevægelsesfrihed, så hælen kan dreje omkring pedalens center. Denne bevægelse i fod, underben og knæ øger komforten og forbedrer trådets effektivitet.
  • Fremragende frigang i sving
    Vi har overført den klassens bedste svingfrigang fra SPEEDPLAY Advanced Pedal System til SPEEDPLAY Power. Denne pedal- og klampeintegration giver stor hældningsvinkel på cyklen ved skarpe sving. Træd med selvtillid og vid, at din pedal ikke rammer jorden – så kan du efterlade konkurrenterne i støvet.
  • Uovertruffen stack height
    SPEEDPLAY-pedalens klassens bedste lave stack height reducerer afstanden mellem sko og aksel. Det giver en solid forbindelse for en mere flydende kraftoverførsel ved hvert pedaltråd.
  • Optimeret biomekanik
    3-akse justerbarheden og den lave stack height i SPEEDPLAY Advanced Bike Pedal System gør det muligt for rytteren at tilpasse sin position på cyklen med maksimal fleksibilitet. Den lavere stack height kan give bedre kraftoverførsel og lavere sadelhøjde, hvilket reducerer luftmodstanden.
SPEEDPLAY NANO-pedaler leveres med et sæt Standard Tension Cleats og klampesurrounds for det mest aerodynamiske og gangvenlige system.
Easy Tension Cleat
SPEEDPLAY Advanced Pedal System har krydskompatibilitet mellem klamper. Køb Easy Tension Cleat (sælges separat) for mindre modstand, når du klikker ud af pedalen.
