Gå til produktoplysninger
1 af 8
Wahoo Nordic
Wahoo Speedplay POWER Dual Wattmåler
Normalpris 9,499 SEK
Normalpris Udsalgspris 9,499 SEK
Udsalg Udsolgt
What's Included?
Tech Specs
Lav lagerbeholdning
Kombinationen af Wahoos gennemtestede effektalgoritmer og SPEEDPLAYs avancerede funktioner placerer SPEEDPLAY POWER-pedalerne et niveau over konkurrenterne. Ved at måle total effekt, venstre-højre balance og kadence leverer SPEEDPLAY POWER DUAL alle de brugbare data, du har brug for til at forbedre din præstation. Par med hele Wahoos økosystem af smarte enheder for at spore, analysere og dele dine fremskridt.
Se komplette oplysninger
Wahoo Speedplay POWER Product Features
SPEEDPLAY POWER DUAL FEATURES
SPEEDPLAY POWER FEATURES
+/- 1% POWER ACCURACY
Lab tested accuracy that provides a precise power measurement for all training efforts.
DUAL-SIDED POWER METRICS
Track, analyze and improve your performance with Speedplay POWER's dual-sided power metrics: total power, cadence and left/right balance. In capturing all three metrics, our sports-science based approach not only monitors power output, but also gives the rider insight to optimize pedal symmetry for a more efficient pedal stroke.
TOTAL POWER
Whether crushing watts on the road or the trainer, Speedplay POWER's left and right sensors deliver total power, the most accurate representation of your overall output.
LEFT/RIGHT BALANCE
The dual-sided sensors in the Speedplay power pedals enable them to provide left and right power percentage data to give you insight and understanding into your power distribution. Whether coming back from injury or trying to improve your pedal stroke efficiency, this data is invaluable for measuring improvements.
WAHOO ECOSYSTEM COMPATIBLE
Pair Speedplay power meter pedals with the rest of the Wahoo Ecosystem for the most connected training experience. Track your metrics outdoors on an ELEMNT GPS Device or control indoors on a KICKR Smart Trainer for consistent data anywhere, anytime.
CADENCE
With its internal gyroscope, Speedplay POWER reports out cadence data to help you identify your sweet spot effort and power output.
EASY APP-SETUP
Our simple and intuitive Wahoo Fitness app offers guided instructions on how to install Speedplay POWER on any bike, calibrate the pedals for accuracy, and perform firmware updates.
DUAL-BAND ANT+ AND BLUETOOTH TECHNOLOGY
Speedplay POWER can simultaneously connect to three Bluetooth devices while broadcasting to an unlimited number of ANT+ devices.
ENHANCED WALKABILITY
The slim profile cleat and rubber texture create enhanced stability when walking in your road shoes off the bike.
INTEGRATED PROFILE
Speedplay POWER and the SPEEDPLAY Standard Tension Cleat create a secure connection and a streamlined profile. The two form a seamless integration that aids power transfer and increases aerodynamics.
3-AXIS ADJUSTABILITY
The cleat can be positioned on the bottom of the shoe and adjusted fore-aft, left-right and rotationally, allowing between 0-15 degrees of float.
ROTATIONAL FREE FLOAT
Speedplay POWER provides up to 15 degrees of float, allowing the heel to pivot around the center of the pedal. This range of motion in the foot, lower leg and knee increases comfort and enhances pedal efficiency.
SUPERIOR CORNERING CLEARANCE
We've adapted the best-in-class corner clearance of SPEEDPLAY Advanced Pedal System into Speedplay POWER. This pedal and cleat integration allows for a large degree of lean on the bike when riding tight corners. Pedal with confidence knowing your pedal won't strike the ground and leave the competition in the dust.
EXCEPTIONAL DURABILITY
Speedplay POWER pedals offer uncompromised durability and minimal maintenance thanks to their stainless steel construction and triple-sealed bearing system.
TEMPERATURE COMPENSATION
Speedplay POWER is tested and proven to provide accurate power data across changing temperatures that you are sure to encounter while riding.
RECHARGEABLE BATTERY
Powered by a rechargeable lithium battery, Speedplay power pedals have a battery life with up to 75 hours.
STANDARD TENSION CLEAT
Speedplay POWER pedals include a set of Standard Tension Cleats and cleat surrounds for an aerodynamic profile and walkable system.
EASY TENSION CLEAT
Looking for even easier unclipping? Speedplay POWER is compatible with our Easy Tension Cleat, which can be purchased separately.
