Wahoo
Hvad er inkluderet?
Hvad er inkluderet?
- Left and Right Pedals
- Cleat Assembly
- Screw Packet
- Quick Start Guide
- Important Product Information Guide
Tekniske specifikationer
- Part Number: WFPRC1S53
- Physical Dimensions: 9,9cm x 5.08cm x 5.08cm
- Shipping Weight: 0,55kg
- Box Dimensions: 15cm x 5,08cm x 9,9cm
- Country of Origin: Vietnam
- Weight: 232g per pair
- Stack Height: 11.5mm (3 hole) 8.5 (4 hole)
- Q Factor: 53mm
- Body Material: Grivory
- Spindle Material: Chromoly
- Bearing Type: Triple Sealed Cartridge & Needle Bearings
- Cornering Clearance: 39°
- Max Rider Weight: No restriction
- Cleats: Easy Tension Included
- Release Angle: Micro Adjustable from 0° to 7.5°
- Pedal Float: Adjustable from 0° to 15°
- Cleat Fore - Aft Adjustability: Up to 13mm
- Cleat Left - Right Adjustability: Up to 8mm
- Walkable Cleat: Yes (adaptor included)
Ikke på lager
Tilgængelighed for afhentning kunne ikke indlæses
The exceptional comfort and versatility of the SPEEDPLAY COMP chromoly double sided bike pedal derives from its confidence-inspiring and stable platform, offering both value and performance mile after mile for cyclists of all levels, from beginners to advanced. Precise engagement, easy clip in, effortless release, and dual-sided entry with the Easy Tension Cleat deliver ease of use and confidence to the rider.
Funktioner
Dobbelt indstigning
SPEEDPLAY COMP-pedalers symmetriske design giver mulighed for indklipning fra begge sider. Ikke mere fumlen, besvær eller at skulle vende pedalen – kør afsted, når lyset skifter til grønt, og klik nemt i.
Forbedret gangkomfort
Den slanke klampeprofil og gummistruktur giver bedre stabilitet, når du går i dine landevejscykelsko uden for cyklen.
Integreret profil
SPEEDPLAY COMP-pedaler i chromoly og Easy Tension Cleat skaber en sømløs integration for en strømlinet profil. Den sikre forbindelse kan bidrage til øget kraftoverførsel, hvilket gør det lettere at nå de eftertragtede watt.
3-akse klampejustering
Standard Tension Cleat kan placeres under skoen og justeres frem/tilbage, sideværts og roterende, hvilket giver 0-15 graders bevægelsesfrihed.
Roterende fri bevægelse
SPEEDPLAY-pedaler giver op til 15 graders bevægelsesfrihed, så hælen kan dreje omkring pedalens center. Denne bevægelse i fod, underben og knæ øger komforten og forbedrer trådets effektivitet.
Fremragende frigang i sving
Vi har overført den klassens bedste svingfrigang fra SPEEDPLAY Advanced Pedal System til SPEEDPLAY Power. Denne pedal- og klampeintegration giver stor hældningsvinkel på cyklen ved skarpe sving. Træd med selvtillid og vid, at din pedal ikke rammer jorden – så kan du efterlade konkurrenterne i støvet.
Uovertruffen stack height
SPEEDPLAY-pedalens klassens bedste lave stack height reducerer afstanden mellem sko og aksel. Det giver en solid forbindelse for en mere flydende kraftoverførsel ved hvert pedaltråd.
Optimeret biomekanik
3-akse justerbarheden og den lave stack height i SPEEDPLAY Advanced Bike Pedal System gør det muligt for rytteren at tilpasse sin position på cyklen med maksimal fleksibilitet. Den lavere stack height kan give bedre kraftoverførsel og lavere sadelhøjde, hvilket reducerer luftmodstanden.
SPEEDPLAY COMP-pedaler leveres med et sæt Easy Tension Cleats for det mest brugervenlige og gangvenlige landevejspedalsystem.
Easy Tension Cleat
SPEEDPLAY Advanced Pedal System har krydskompatibilitet mellem klamper. Køb Easy Tension Cleat (sælges separat) for mindre modstand, når du klikker ud af pedalen.
