Gå til produktoplysninger
1 af 5
Wahoo
Wahoo POWRLINK ZERO Left Sided Power Pedal (Single)
Normalpris 6,499 SEK
Normalpris Udsalgspris 6,499 SEK
Udsalg Udsolgt
Lav lagerbeholdning
Built on the cutting-edge SPEEDPLAY Pedal System, POWRLINK ZERO single-sided power pedal delivers reliably accurate power and cadence data in a race-proven pedal system. This powerful combination creates an unrivaled power pedal that helps cyclists optimize performance by providing the visibility, adjustability and efficiencies needed to break through to the next level. Pair with the Wahoo ecosystem of smart devices for a more full picture of your data and performance, and to track, analyze, share and improve.
  • Physical Dimensions: 9 x 4cm
  • Country of Origin: Vietnam
  • Weight: 250g | 0.55lbs total (Left: 138g, Right: 112g)
  • Stack Height: 13mm (3 hole)
  • Q Factor: 55mm
  • Body Material: Grivory
  • Cornering Clearance: 39°
  • Cleats: Standard Tension Included (Easy Tension Compatible)
  • Cleat Left-Right Adjustability: Up to 6mm
  • Battery Life: Up to 75 hours
  • Connectivity: ANT+, Bluetooth
  • Max Rider Weight: 113kg
Se komplette oplysninger
