Gå til produktoplysninger
1 af 1
Wahoo
Wahoo Power Switching Adapter CLIMB
Normalpris 699 SEK
Normalpris Udsalgspris 699 SEK
Udsalg Udsolgt
Lav lagerbeholdning
Take your KICKR MOVE ride experience to a whole new level. The KICKR CLIMB Base Adapter is required to use the KICKR MOVE in conjunction with a KICKR CLIMB.
NOTE: The use of KICKR CLIMB and KICKR MOVE together, require you to use the KICKR CLIMB base adapter to avoid damage to the KICKR CLIMB or other property.
SPECS
  • Part Number: WFBKTR5BASE
  • Product Weight: 2 lb / 1 kg
  • Product Dimensions: TBD
  • Max User Weight: 250lbs // 114 kg
Se komplette oplysninger
