Gå til produktoplysninger
1 af 4
Wahoo
Wahoo KICKR Desk – Indendørs cykelstativ til hometrainere
Normalpris 2,700 SEK
Normalpris Udsalgspris 2,700 SEK
Udsalg Udsolgt
WHAT'S INCLUDED?
  • Desk table top
  • Non-slip table mat
  • Adjustable legs
  • Lower frame
  • 2 caster wheels
  • 2 fixed wheels
  • Assembly hardware
  • 2 hex assembly wrenches
  • 5 cable holders
  • Assembly instructions
SPECIFICATIONS
  • Base (Width x Depth): 71 x 76 cm
  • Desk Top (Width x Depth): 71 x 36 cm
  • Adjustable Desk Height (from floor):88 x 119 cm
Lav lagerbeholdning
Justerbart cykelbord – Wahoo KICKR Desk til smart og fleksibel indendørs brug
Wahoo KICKR Desk er designet til at holde alt inden for rækkevidde under træningssessioner, og Wahoo KICKR Desk kan også bruges til multitasking. Brug det som et indendørs cykelbord med din cykeltræner eller som et stående bord på dit kontor. Det er fuldt justerbart, så du nemt kan optimere og skifte mellem at stå, sidde oprejst og cykle med hænderne på håndtagene.
Se komplette oplysninger
KICKR Desk
Streamline your indoor cycling sessions with the versatile Wahoo KICKR Desk. Adjustable height and built-in tablet and device stands make it perfect for multi-tasking or following training plans. The sturdy construction and integrated wheels allow for easy repositioning in your home gym. Enhance you indoor cycling experience with the Wahoo KICKR desk.
  • New - hooks on legs can hold wheels or towels
  • New - two recesses for water bottles
  • New - USB cable holders
  • Built-in tablet and smartphone stands and holes to connect all your tech
  • Wheels for easy movement
  • Slip-resistant rubber desk surface
  • Fully adjustable
    Raise or lower the desk to sitting, riding, or standing position.
Why KICKR Desk?
The Wahoo KICKR Desk is designed to make indoor training more comfortable and efficient. Unlike regular desks, it adjusts easily to match your riding position, keeping essentials like your laptop, phone, and water within reach. Its sturdy, non-slip surface ensures stability, while the open design works with any trainer setup. Plus, when you're not cycling, it doubles as a standing desk. If you train indoors regularly, the KICKR Desk is a smart investment for a more seamless and organized experience.
BIKE TRAINERS
Explore Wahoo Trainers that pair well with the KICKR Desk
EXPLORE
